Run Flat Tyres Any Good?
Yaumeister
This was covered in the wim forum... Your main problem is that all the suspension will need to be replaced.... Anyway here is the "RFT" topic.
The 'RFT' concept does have a point regarding safety and hazard, but the evolution belays a few convenient areas not on public display.........so in true wim fashion........
Principle
The RFT can resist and react to most forms of deflation, sudden or progressive and permit the driver to continue with the journey regardless of the deflation, valuable for safety and it assures the owner that nothing would deny the destination other than fuel or the M25.
Evolution
The concept has been realised over many years, Dunlop suggested the 'Denovo' which was a tyre locked between a split rim, this wheel had no internal recess that allowed the tyre to 'off-set' and detach from the rim, this also involved internal canisters that would be crushed and released a gel to keep the tyre cool... at the time the concept was very expensive and ultimately failed, apart from cost the fundamental flaw was if the tyre deflates then it was 'scrap'
Following this commercial failure Dunlop abandoned the concept of the 'split rim' and introduced the 'Demlock' tyre, this carried the same concept and placed the gel in the tyre without the canisters..... a new evolution of wheel was designed to support this but very costly... in fact Jaguar was the main recipient and offered this safety factor deep within the sales campaign... again this failed.. fundamentally for the same reason if the tyre deflates it is 'scrap'.
Then things went quiet..........
Very quiet!
With the birth of the new Mini One/Cooper in 01 Pirelli answered the run flat question again with the 'PAX' design of tyre and rim, basically the rim has internal shoes that supports the tyre and simply replaces the air after deflation... but a new problem was born?.... not only was the tyre scrap after deflation but now only the main dealer had sufficient machinery to remove/ replace the tyre, in time ultimately i feel this will also fail.
Today's evolutions expand on past examples, now the RFT will fit any rim and most shops should be able to fit/ remove the tyre.... but something is missing?..... where is the gel.... where are the internal shoes.... what keeps the tyre cool once deflated?
Construction
The evolution is evident, make the tyre wall armoured and it will suspend the car.....
So they did...... the new Goodyear and Bridgestone are now OE within BMW and associated marques, Pirelli have taken a back seat for now..... but there is still a problem?
The tyres needs to communicate with the car directly via internal censors or externally via the ABS, visible activation on the dash will need to be re-set/ turned off by the dealer, this i feel angry about! (another topic maybe)
A warning
If you have RFT then it's a done deal... due to the armoured construction of the tyre the suspension has been 'down graded' to accomendate the tyre, you cannot deviate from the set-up unless the suspension is also modified, so in essence the tyre/ suspension is a package and must be considered as final.
Oh and to add insult even the new variations of 'run flat tyre' once deflated is 'SCRAP'
So what it comes down to is this:
In the unlikely event of a puncture sufficiently serious enough to rapidly deflate the tyre whilst moving at speed, you can carry on driving... for a bit... Admittedly this type of puncture has happened to me once, but that was 300,000 miles ago and I don't know of anyone else it has happened to. And I check my tyre pressures a bit more often since those days!!! ;)
In return you get worse ride, worse handling, significantly greater expense in the event of any puncture, and a bit of extra space in the boot.
Not all that appealing to me, to be honest...
Mike
Mike
Reason I asked is because I'm considering a LPG install, and the tank will be placed where the spare wheel is, guess a can of tyre foam will do.
