What Do You Think Of These Rims? Will They Suit My Is200
eightysix
Hi, I can get these rims brand new original toyota (rav4), for 290 pounds (for the whole set).
The ET of these rims is 45, and 5x114.3 so they should fit without a problem right?
What do you guys think of them, will they suit my is200.
Can someone do a photoshop on a silver is200?
what is the radius ? ET?
They look great mate, What He means is what inch size are the rims, 17", 18" or 19" ?? the bigger the rim the smaller the tyre wall you would have to buy to allow it to fit, with out rubbing..i think (depends if it is lowered).. :blink:
Hope it helps.
Dibslpg
ET is offset - it will be stamped into the back of the wheel, the standard offset on the old IS is 50
Always thought the standard offset on the old IS was 45 mm. :unsure:
Anyway...
OFFSETS
FRONT
width | offset | tires range (width)
7 = 40 and up 215-225
7.5 = 42 and up 215-235
8 = 43 and up 215-235
8.5 = 45 and up 215-225
REAR
7.5 = 40 and up 215-235
8 = 42 and up 215-245
8.5 = 45 and up 225-265 (255-265 requires rolling or having lip)
9 = 49 and up 235-275 (MAY require rolling or shaving lip)
9.5 = 52 and up 245-285 (MAY require rolling or shaving lip, 285 may require more modification)
10 = 45 and up 255-315(requires pulling fender)
the lexus' ET is 50, these rims are 45, will these fit without a problem?
The standard ET is 45 mm so it's the same offset. My post before this one gives you the wheel sizes and tyres that fit, so for 7" width an ET of 40+ is going to fit front and rear with tyres within the 215-225 range.
same her :blink: i Always thought the standard offset on the old IS was 45 mm
any way they will fit ok with ET of 45 :winky:
My IS200 Sport is currently sat on my original IS250 17" rims which are 8" wide with 45mm ET on the front and 8.5" wide with 50mm ET on the rear...no problems. :)
Just don't blame the council if you go over a pothole and break your wheels. Anything less than 50 is asking for trouble on UK roads, unless it's for track day use only.
