Is200 'box
Lamphant
good day fellow members....
i have plans on puttin a 3sgte into an IS200 and was wondering if the IS200 gearbox would bolt right back onto the 3SGTE.....and would it be able to withstand the torque and would i need to make changes to the rear-end and what would be a good one to use to harness that kind of power
thanx
the gearbox is the same, however you will need a different bellhousing, as the starter motors are on different sides
also the bracket which supports the gearlever will need moving to the second location to fit correctly, it will become evident when u come to do the swap
