Big Question
what would you do?blitz supercharger or a hks gt-rs turbo kit?
not a question of makes, the question should be. Supercharger or turbo.
You can always keep adding to a turbo kit making it more powerfl, sperchargers are some what limited by the amount off boost they produce.
I say turbo
depends what you ultimately want......
the supercharger option is more expensive as a single unit, the turbocharged option allows for some degree of expansion later down the project if needed
the supercharger will have a generally longer service life, but again supercharger/turbocharger life is dependent on use, or abuse
ye i think a SC would be easiest.
the sc would need a lot of attention also . im getting a power enterprise turbo installed in mine. i looked at the hks one its more expensive and dosnt come with as much as the pe one . both would require a good bit of work / mapping
both id say require equal ammounts of attention
