Headlight Cluster Removal How?
Hi all,
My drivers side light is badly condensed up on my IS200SE. How do you remove the light? I can only see one bolt on the slam panel and one nut just under front wing (almost impossible to get at) How is it fastened at the bottom? I need to dry it out and reseal it. I don't want to buy a new light unit if I can help it.
cheers
x2 10mm nuts behind the headlight, just pull your arch liner back and you will see them. Then the one 10mm on the slam panel you mentioned. After that there is a clip holding the light in place at the bottom, you need to be quite forceful to get the light unit out as its quite tight.
Thanks guys :D
