Wtf I Do Not Get This At All
making blue ac uni using loads of 3mm leds
i wired them up in series 6 per group tested on DC 12 power supply all light up mint
go to car try it there / nothing
am like hmmm ok out comes volt meter check correct way round n they r getting voltage all ok soo y the fuk aint they lighting up
go back inside bk on the power supply again they light up
so for a laugh wire a 1 LED up to the unit in the car and bingo it lights up WIRE THEM IN SERIES THEY DONT
now im not an eletric *** or nothing but i no **** wired in series works ANY WERE dont matter wot **** power sorce its comin off
yet in the car any leds wired in series just wont light up only when in parerall
proper done in have to rewire whole unit now so each LED has its own resistor n is pareall with the 12v
just dont get it
ok just ran a test in the car
2 leds and 12v resister in SERIES works
3 leds on own work SERIES
4 leds on own work SERIES
5 leds on own in SERIES very dim (2-4 same brightness)
6 leds on own in SERIES just dont work
somin foookin weird goin on still dont get y i get this result in the car and not on a normal 12v dv power supply inside house
my ac unit is wired in groups of 6 y it aint working still dont get y when u get to 5leds ders such a loss of current ??
******** EDIT ********
ok might of worked this out LOL
i thought they were like 2.5 volt thts y i got 6 in series for my 12v
power supply im using inside is actually 13.5 volts car is dead on 12v
when i was deciding on the grouping i found tht 7 in series on the inside psu made them go very dim
leds r actually 4.5 volt LOL so should be using 3 in series really and tht works fine in the car n 4 seams to work as well looks like 5 just drops to much current and they go very dim n 6 just kills it all together
have to wire in groups of 3/4 me thinks
Something wrong with your keyboard? Just out of interest, why do you always type chav in short hand? Or is it you just cant spell that well? :shifty:
PM fargo, think he made his own kit.
It's simple electronics mate.
In Series the voltage is split but the current stays the same on all LED's and in Parallel the voltage is the same on them all and the Current is split. So when you put them in series there isn't enough voltage to turn them on.
You have to put a resistor on each LED (on the same side on them all as well).
Hope this helps you understand.
Ps I think Fargo doe's explain that you have to put them all in Parallel in the "how to" guide.
Think Stav has answered your question mate.
Also your sig picture is too big
Signatures
Signatures must be kept to a maximum of 6 (six) lines, and may contain no more than 3 (three) images.
Images must not be larger than the following dimensions
- 468 pixels in width
- 60 pixels in height
Signatures may be edited or deleted without notice by a member of the moderation team.
ah yeah think i get it now
i used his intructions but cant see how all the resisters fit in as well lol so thought bah wire in series and forget the resisters lol
will rewire soo all in parallel now
---- lee_iceman -----
but aint ur sig OVER ALL bigger then mine ?? just built up of lots of mini sigs lol
Good luck, stick some pics up when your done.
As for the sig, yeah overall mine is bigger but abides by the T&C. Just letting you know thats all incase you login one day and its gone.
hehe im hoping admin aint tht evil over a slightly larger sig lol
been like it for like a month so think they r ok with it
i took some pics other night
put 5 of them really bright 1w 180degree leds into dash result was amazing totally blows the ebay kit away (just hoping they dont die)
put 2 in the traction / snow button (looks cool) altho now snow button only works every so often hmmm guessing somins lose
got the lcd display done + the 4 leds for the buttons done on the ac control just have to rewiring the main lamps and that be done as well
den will do sig lamp and the headlight dim + rear fog lamp
might do the door handle button thing as well
is all lookin mint tho
coz me got dem morse blue clear door light things + blue headunit so like whole car blue now
will stick loads of pics up when done
innit with tht clear plastic light guide been jammed between pcb really is very little room
what did u use to place between the pcb n the light guide tho to project it from all the LED solder connections ?
iv just cut out some plastic
