Mk1 Lexus Gs300 Aerial Trouble
OK so today i turn on my car and notice the aerial was already up.
I turned the engine of and the aerial wouldnt go down, and it made a horrible grining noise.
When I got home I unscrewed the aerial nut and the aerial came out. At the end there is a plastic cord.
How do i get the system to accept the aerial back in?
any ideas??
:offtopic: The red ! came on today. The turned the engine off and back on and it was gone. What does the ! mean??
i think you are talking about the rear light warning signal ,this also comes on when brake fluid is low .
i dont know if this will help.
:tomato:
http://www.lexls.com/tutorials/audio/powerantenna.html
i had similar problem with my gs300, 93 reg. the plastic cable had slipped out of the motor so i had to reinsert it but this is a common fault.
:tomato:
it will help him if the light is still on .R.E the last sentence of his post :yawn:
Regarding your antenna-troubles...youre gonna have to buy a new antenna-shaft that has a complete "plastic cord" :) The grinding noise youve heard is most likely the antenna-motor not being able to grap the cord...cause its broken...
