Induction Kit
Can anyone help i have fitted a induction kit, but the pipe that goes across the engine from the throttle body to the filter seems to get alot of heat from the exhaust manifold. Can anyone think of any ideas to reduce the heat as there is no point in having cold air feeds to the filter if it heats up.
Anyone with ideas welcome?
prolex filter keeps away from the exhaust manifold.
Stav, is that any good and did you get it off eBay? also the ducting, is it the original box modified?
can those kits not swing around to come down then across?
No i bought it from another member on here and it came like that.
Except i've changed the filter to an enclosed one.
The ducting is an IS300 inlet scoop that came with it.
It's a good idea about it swinging round as well but i'd have to extend the breather pipe.
stav
