Doughnuts?
There are two types of car that can do them RWD and 4WD.
The IS is RWD so i'm sure if you really wanted to do them you could! :winky:
Wouldnt recommend it due to tyre wear and wear and tear on your car. Plus don't try it on the motorways :lol:
Can the IS do them?
They can although even with traction control off its difficult unless you get some forward momentum happening first as the flaming car keeps gripping! Quite hard to do if you're starting off stationary too! But that might just be my in-experience.
The IS250 however, WILL do them on a dry concrete surface from a stationary position! i recommend using the car park at Harry Ramsdon's in Guiseley. :D oh and a courtesy car always help.
This topic is now closed to further replies.
