I had my car up on the hydrolic lifter for the first time on saturday and found that the bushes on the trailing arm connecting to the hub where totally shot, i mean they weren't there!!! Does anyone know where i can purchase these from?
Also after a new roll bar link - the small one connecting to the main anti roll bar.
Thank you
Mat
Also try LPD autoparts USA, they should be on eBay.
I got rear axle carrier bushes and trailing arm bushes from them.[poly]
Good price and decent service.
Cut through the outer metal of the old axle carrier bush[ carefully] then press it out.
I have'nt fitted the trailing arm bushes yet. :)
cheers
well the trailing arm bushes dont look to difficult. Its alot easier on mine because the bushes aren't there its so badly worn. and popping them in is made easy with a vice. One thing though, it looks easier if you just undo the bolt and work with it with the hub attached.
Best wishes ROYT
Mat
