Widest Rears
DEANOROW
Im looking in to getting some staggered 19 inch wheels and was just wondering how wide i can go on the rear ?
I want quite a deep dish at the rear, im thinking probably 9.5" with no arch mods ?
Any ideas ?
Deano
It's the offset that can be the problem when you want a nice deep dish. The IS has a high off set. The higher the offset the smaller the dish. I think Mr.Singh has very wide rears on and his are staggered fitment.
I have looked into this myself and only certain designs of wheel will suit what you are after.
Any ideas ?
Deano
You can go 10s on the rear on the right offset... Hell you can go 11s if you were after some serious lippage...
I have 9.5s which came on a +55mm offset, now i'm running +38mm and super stretched rubber.
It won't help with straight line speed going 19s... but the width defo helps with traction
Thanks for the replies :D
Mr Singh,
What sort of offset would i need to run 10" rears ? as ive just found a really good deal on some staggered 19's
8.5 at the front and 10" at the rear ?
Deano
