Rear Hub Bush - What Is One Please
dibsLPG
my Lexus Is200 is becoming noisy in the rear lately (knocking) when going over bumps..
I have checked the shockers and no noise when bounced up and down stationary. Checked the callipers/pads etc.. all fine.
Had it up on a ramp and the Mechanic bashed the tyre and rocked the rear drivers one, after umm'n arring :shifty: said it's your Hub Bush. :blink: Points to it: sits between the Hub and the Disc it think… Has anyone come across the same problem before?
What is one and how much am i looking at please? Might has well replace both rear one at the same time.
I need to replace them urgently since my MOT is coming up very soon.
Has usual your wisdom is greatly appreciated.
Dibslpg.
i cant remember a bush between the hub and disk, bearing yes but not a bush. if it appeared he was not sure take it somewhere else as u might end up paying for work that isnt required
Thanks mate, i will get a second opinion on that one... :D
Will a bearing make that noise (knocking noise going over bumps) if worn too?
If so a small part and assuming it can be easly replaced?
Dibslpg
not really unless its 100% fallen apart then u would know it!!! worn bearings norm generate a rumble.
to replave the bearing isnt such a big job but it takes a while and u need a hydraulic press to remove and install the bearing
