Think I may have a puncture. Went to top it up with air tonight at Tescos and couldnt get the bloody air caps off!!
Tried and tried but failed. Whats the best option if I do have a puncture. Kwik fit or just bit the bullet and go to Lexus?
Any ideas on cost would be good also!
If you go to Lexus they will probably charge you an hourly rate to take your caps off! Just go to nearest Kwik Fit or similar. If it's a puncture they will fix it.(So long as it isn't the sidewall of the tyre.
I would imagine it isn't the sidewall 'cos it would most likely be flat by now.
Before putting the caps back on just put a touch of vasaline on them first.
Should never have been on that tight in the first place.
