Toyota Transponder Same As Lexus?
:question:
Does anyone know if the Toyota transponder (Valeo 736670-A, CE0523 on key) from an Avensis can be programmed for a Lexus. I know the key is different but the 3 button case is exactly the same so I know the transponder will fit in the Lexus case. I would like to think Toyota/Lexus have the transponder as a standard part which is individually programmed.
Help is much appreciated!!
Gary.
