Hi Folks,
has anyone purchased themselves a second hand front brake caliper?
Just wondering what they are going for and how you got on?
my driver side seized up so I had to get one today.
Also, I think that S1 to S2 the calipers changed, I think from 2 pots to 4 pots, is that right?
The reason I ask is that the car I got a caliper off was H reg and it looks slightly diferent to the one I took off (mine's a K plate), mainly due to the position of the brake line.
Pistons are the same size, it mounts the same and seems to work just fine!
maybe my mpg is about to go up... must have been binding for hundreds of miles!
the one that came off, I toook the boot off and the piston is pitted so a seal would not cut it. I speke to Lexus Leicester and they said they could get a seal kit but not the piston, seal kit alone was over £40 plus vat!
