3" Cat Back Exhaust
Does anybody know of any off the shelf 3" cat back exhaust for the is200 or will i have to have it custom made e.g powerflow ?
I was going to get a kazama 2 but Dave informed me that the pipe work is the same as oem and that i would be better off with a 3".
Any ideas ???
Deano
Cheers Chaps.
I will go and see what my local powerflow dealer has to say and then give blueflame a try. Going to try powerflow first as its literally 2 minutes down the Road.
Thanks again
Deano
Hi Adie,
Its going to be turbo back but i need to find a suitable cat, I posted another thread about the one im looking at from tsl-motorsport for the evo and the possiblity of incorperating this in to my exhaust system.
Any idea if this is possible ?
No mate. Can you not just fit a full 3" freeflowing system and then replace the cat at MOT times? This is what I've done as I don't know of a sports cat that'll fit. I know it's a pain in the arse but is a small sacrifice to have to make.
Or you could try and find an understanding MOT tester :shifty:
Taking the cat off doesn't mean an mot failure. I was told by my local mot centre that they will pass it with or without a cat as long as it passes the emission test. Just don't know the chance of passing without the cat. I was told that old cars don't have cat anyway and they pass mot.
Thanks for the replies chaps,
I would really prefer to have a sports cat in from the start, but if its going to cause loads of problems i may have to just swap the cat come mot time :winky:
I will have a word at the exhuast place when i pop in to see if they can source them.
Cheers
Deano
As I said mate I think you're going to struggle to find a sports cat for your car, so will have to swap over at MOT time, :blush:
But there are understandable MOT testers out there :winky:
D'accord.............. :D
  • 1 month later...
from my own personal experience, removing the CAT from the exhaust system attains zero power gain, and hikes the fuel consumption massively.
Replace the catalytic converter with a high flow item. Your wallet, rear bar - and the environment will thank you
