Brake Lip
stuie
Ive got a bit of a lip forming on the front disk on my 200. Whats the rules and regs on this whats safe whats not and how easy is it to change disks and pads? Ive done motorcycle and bicycle disk brakes so im reasonably competent when it comes to basics
Info I have is that the front discs are 32mm thick when new and the minimum thickness is 30mm so wear limit is 2mm e.g. 1mm either side.
And to answer the other question they are easy to replace.
