Which From This List?
Please could someone highlight from each list, the sizes that are suitable for IS fitment?
Wheels are listed as follows: PCD / Diameter / Width / lip size in mm.
Wheels are listed as follows: PCD / Diameter / Width / offset / Rim Depth / Disk type.
Many thanks and it's really appreciated,
J
So, from the list, would 40 / 42 / 43 / 48 offsets be fine?
J
With what size wheel Jamie 17, 18 or 19inch and what 7.5j, 8j, 8.5j, 9j or 9.5j ?????
You will be better off finding the wheels you want, then see what sizes thay come in :winky:
I was looking at 18" mate - all the sizes in the above lists are for 18" fitment, so I just wondered which from each list, which was the most suitable.
Each list is a different wheel model / type.
J
Well then 7j = 40+et, 7.5j=40+et, 8j=42+et, 8.5j=45+et, 9j=49+et
The wider you go the more chance you might require arch rolling.
Alright there mate,
Im running 18's with a 7.5=et42, i was told on the phone that they would fit no problem, the rears do, but the front needed a 3mm spacer on there!!! They still fit and look well....the dish on them is about 2 - 2.5 inch deep if thats any help mate!!
Chris
