Satnav Question
I went to program my satnav with Tony's address on Saturday and went to put in the postcode (which I thought I had done before), but I couldn't find the option to do it.
Am I going mad or does the satnav only take addresses not postcodes?
If I update the Satnav DVD does it give you the facility to put postcodes in or is it just a map data upgrade?
Im not sure it does postcode lookup if I does I certainly havnt found a way to do it
I believe that you can only find address by road name and then house number, Ive asked Lexus before if the newer updated discs has any additional features and its only the updated maps. Not sure if the DVD version are the same as the CD thou?? :whistling:
