3s-ge And An Is200gearbox
llamapoo
Hi im new to the site!
ive been looking at alot of threds on this sight but i cant find a definitive answer as to is the standard is200 gearbox fits the 3s-ge.
i know the bell house is different.
i know i will have to reset and cut the gear leaver hole
so i have a few questions?
1) is the is200 standard gearbox a 2 piece gearbox with a removable bell house?
2) can i just bolt a 3s-gte bell house to a is200 gearbox and strap that to a 3s-ge?
3) what other problems will arise?
Regards
Matt
the gearbox,s are identicle
the bell housing need changing because the starter motor hole is on the wrong side for the 3s-ge
the possition of the gearlever can be adjusted by mounting on the different mounting lugs located on the nose of the gearbox
sounds a bit silly but s3ge engine with is200 box in a Ford Escort Mk1!
www.people-productions.co.uk is my website with my escort with a nissian 200sx engine.
so waht i will need is:
S3GE
S3GE Bell House from ?????
Is200 uk spec gear box?
all this will mate up? clutch?
S3GE
your best bet would be to source as altezza engine and gearbox,
but otherwise yes, 3sge bellhousing from toyota altezza(japanese is200) and a UK gearbox, however if you can find an altezza gearbox first off this will be better
