Hi, I have a couple of small problems with my GS300, just wondering if anybody here can help me out with these at all.
First, is the heated seats, they don't seem to be working properly, if at all. Any ideas as to why this may be? I really don;t know what I'm going to be looking for on this one!
Secondly, is the rear drivers side window, it doesn't work. Obviously this isn't a big problem, but it is something I would like to fix if I can. I have heard that the motor often packs up on this, is this true? And if so, is it easy to fix?
I think that's all for now!!
Thanks in advance.
Thanks in advance.
If it's a Mk1 the heated seats take a long while to warm up especially if both are on at the same time
Thanks in advance.
It is indeed the mk1. How long are we talking here? I have left the passenger one on for a good 10 minutes with no noticeable affect.
Thanks in advance.
On mine it seems to have a mind of it's own, sometimes it heats up quickly other times it takes about 15 minutes before you suddenly remember you switched them on
Right I'm pretty sure mine aren't working then (or at least the lassenger one isn't, hard to tell about the driver one as I'm always sitting on it so it heats up naturally anyway!).
Has anyone got any ideas as to what I can check or look at to try and find the cause of this problem?
Cheers.
