Anyone??
Without looking, if there is no obvious adjustment on the catch (unusual) are there rubber bungs at either side on the front edge of the bonnet ? if so these can be screwed in a bit to lower the front of the bonnet. Sounds like the bonnet latch may not be catching as well so check the diameter of the bar on the underside of the bonnet, get a screwdriver with the same diameter and press it into the catch to see if it holds/locks it if not sounds like the catch is u/s.
Anyone??
Catch locks fine with a screwdriver it just seems that the bonnet won't quite drop down enough to fully engage, even though it is clearly as far down as it will go.
Will have a look at the rubbers tonight
