Will These Fit ?
Guest inicol63
Diameter is ok but as far as I know the offset isn't it should be 35-45 where as those are 20
Whether you can get spacers to fit to make up the difference I don't know - hopefully someone who does will be along shortly :)
Guest inicol63
Cheers for your comments janey!
I was thinking the same but the guy said that they would go straight on with no alteration's needed.
I shall see if someone can else can give me any pointers.
thanks
I am pretty sure You will need hubcentric spacers and then you will need to check for clearence.
Ihave 20" on mine but they needed a hubcentric spacer to stop catching on the inner wing. Yet they fit perfect on the GS model
If he is willing to guarantee a full refund if they don't fit then try them. But I don't think that is going to happen.
Guest inicol63
B)-->
QUOTE(T7RY B @ Jun 18 2007, 01:56 PM)
Hi the guy has offered a full refund should they not fit, however i dont want the bother of returning the item and trying to get my money back.
I have sent him your comments and i await his reply.
Thanks for your help..
