Is Transmission/diff Ratios
wagonist
I'm curious to find out whether the Euro spec IS200/IS300 have different transmission and diff ratios to other places like Australia/Japan. If you know what they are & what kind of revs matches the speed, could you please post them.
Because you guys have higher speed limits, I know a lot of other cars have taller gears so you're not revving the guts out.
As far as I know, all IS200's haven the same diff ratio. Obviously the manual and auto will have different gear ratios but other than that they are the same.
The IS300 has a different diff ratio which gives higher top end speed. I am on the look out for one of these.
