Is200 Sport Ecu Reset
Two ways mate, hardest is to remove the negative Battery terminal connection for 10 mins plus, easiest is to remove the EFI and ETCS fuses from the fusebox in front of the Battery for a few minutes, both ways will reset the ECU for you :)
