Torsen Diff For Is200
Anto
Info that i have gathered relating to
RS200 Altezzas ...
1998 to 05-2001, Manual & Auto final drive have a ratio of 4.1
05-2001 to 2005, Manuals were changed to 4.3 , whereas no change for the Auto's
Torsion LSD standard on Manuals, option on the Tiptronic auto's
From pics I've seen the diff's for a IS200 are different and are not a straight swap....
i did alot of research on the differentail units.
the units are identical inside, the European unit has cooling fins cast into the underneath of the unit.
the auto HAS a different ratio to the manual
Yes, in the japan and the european market and all the world there are only type lsd centre for gxe10/sxe10 (7.5 inches) the part number 41301-53010 and pn 41301-53020 for jce10 (8.0 inches) but there are a lot of types of differentials, ratios and shafts.
Also there are a lot of types of open centre/diff.
I am afraid with differential's adjustment with washers plates , so it seemed a good idea to buy a whole differential with ratio 4.100 and lsd.
Strange..... My IS200 has an RS200 LSD fitted,, no difference in final drive with IS200 LSD. There were two differences though: no cooling fins on the Altezza diff-housing, and I had to use the old axle stubs as they are 6-bolt on the Tezza instead of 4-bolt on the IS200. :g:
From the pics above there must have been quite some variations, only you wouldn't get to 146 mph with a manual RS200 and a 4.3 final drive, with a 3,909 you would.
Maybe someone can complete the gaps in this story
Cheers,
RX-Men-8
Cheers,
RX-Men-8
Are you sure did not have a 4.100? The difference of 3.9 to 4.1 in kph/1.000 rpm is less than 1 kph/1.000 rpm.
You can check this way:
Make two marks as shown in the picture and turn it 4 revolutions
before the mark, 3,909:1
after the mark, 4,100:1
Cheers,
Carles.
Ehhh.. I'm not going to unbolt it for that ;) But I won't contest that's the best way to check.
It will go to a max speed of 215kp/h (GPS) @the rev limiter in 6th line like before. And 3,909/4,100 * 215 would only be 204.
Greetz
Rx-Men-8
