Goodbye Floppy!
maneesh
Remove OEM springs, OEM shocks, OEM anti-roll bars
Add Tein CS coilovers, TRD anti-roll bars, upper and lower rear braces, corner weighting, lowered ride height, proper geometry
equals a much more grippy and less sloppy GS300 Sport...it's like a totally different car to drive.. :o surprised a Golf GTi on the bends today...hehe
Now that I can generate more G force on bends, I wish Lexus had put bolstering on the driver's seat...LOL..
More on the install, including pics soon.. :winky: :)
P.S Dave, my rear lower brace installed super quick. All you need to do is take the bolts which are for the petrol tank straps off as well as the subframe bolts, and support the petrol tank whilst you fit the brace. HTH
Sounds great Maneesh,
The crap handling of my GS is the main reason I am thinking of changing cars.
What sort of price would a set up like set me back?
despite getting the parts cheap via the states, it's cost me 1.5k including the install and setup.
Will take you for a drive soon, so you can see what an improvement it makes over the standard setup.
The GS has a balanced chassis, it's just setup for comfort from stock
Thanks to Tony Bones for his referral to Chris Franklin at Centre of Gravity. Another man totally into geo and all the technical talk. If him and Tony met up, the conversation would be in another world.... :unsure:
Pics!!!
Chris was adamant that ride heights should be measured properly before the install
The pimp ride minus wheels!
Tein CS vs OEM setup
These are Tein Version 2
Rear chassis brace and rear anti roll bar installed (it's hollow, but bigger, OEM was solid and smaller)
Front anti roll bar installed (it's solid, OEM was hollow)
The man himself
No, it ain't a TRD trained mechanic, it's ME..Chris let me have a go at some of the hands on work...
Chris getting the scales ready for corner weighting
Apparently, you must simulate normal weight of car, so in went the weights on driver's seat to simulate ME!
This was the final result of the corner weighting, 50.2% of weight spread from across opposite corners of the car
Finally, the geo got set properly
A few tips for anyone else...
The car is now lowered to a point where I have too much negative camber, and no camber correction kits exist for the GS
The corner weighting really DOES make a difference, I drove the car before it was done, and it was crap to drive. The corner weighting and geometry really made it brilliant!
What effect will this have, will the tyres wear?
yep, the tyres will wear prematurely, but I'm looking into a custom engineered option to restore the correct camber..it's not a problem if you lower the car to normal GS300 Sport height, but I went lower for handling and looks... :shifty:
The TDI custome rear toe adjusters will fit the GS.
