Installing & Fitting Gauges
Hi there everyone,
Does anyone have any documentation (possibly with the gauges they have bought / fitted) along with images as to how to fit gauges?
I'm okay with most things, but this is something that bamboozles me as I'm not too sure where to begin. I haven't purchased any as yet, but will be looking to soon.
  • Boost Gauge
  • RPM Gauge
  • Any suggestions for a third? Maybe Oil Temp / Oil Pressure / Water Temp?
Many thanks,
Jamie
you already have a RPM guage............
boost/egt/oil press/oil temp are good chices choices even
also have a water temp and oil pressure :whistling:
AFR gauge would benefit a supercharger
aaaaaaaaaaaaaaaahem
my lex may have been awol for 14 months.........but i dont recall oil pressure :whistling:
aaaaaaaaaaaaaaaahem
ok!... you have a red light with an oil can symbol on it
when pressure gets low it lights up
not quite a gauge admittedly :winky:
aaaaaaaaaaaaaaaahem
had me wondering though........least ways my memory is not totally shot :crybaby:
So, I am wanting to fit:
RPM Gauge (a feed can be taken from the cluster I gather)
Boost Gauge (not a clue)
Sadly, an AFR gauge isn't offered in the range that I'm looking at. The choice I have is:
Boost Gauge 0-2 Bar Pressure Scale, minus 76-0 cm-hg Vacuum Scale
RPM Gauge 0-10000 RPM Scale
Oil Presure Gauge 0-7 Bar Pressure Scale
Water Temperature Gauge 40degC-150degC Temperature Scale
Oil Temperature Gauge 40degC-150degC Temperature Scale
Voltmeter 8v-18v Scale
Vacuum Gauge
I definately want the boost gauge - which other two would you recommend?
Many thanks,
Jamie
Why do you want the RPM gauge mate, I'm confused, does it do something the standard rev counter doesn't or are you planning to do away with the existing one :blink:
Aye Aido, it doesn't make sense really does it tbh :baaa: Scrap that one then ;)
Okay then, boost gauge defo. From what others are suggesting, the other two I should opt for are the oil and water gauges - both in the temperature variation, or do you mean oil pressure and water temperature?
Many thanks,
Jamie
Many thanks,
Jamie
Oil + water temp
have a good look around for boost gauges also and get a low pressure version. the standard TTE pressure is approx 0.35 bar and as most gauges (mechanical) are upto 1.5 or 2 bar the needle wont move much and wont give you a geat deal of warning if you have an air leak somewhere.
another option is to go for a low pressure bar/psi gauge from a gauge supplier and put it into your own housing - the gauges are about £20 - 30 on thier own. There are plenty of companies in the UK that supply gauges so if you decide to go down that route you wil have no probs finding one.
