Remove The Plates
Looks like the plate is just stuck in that black housing - can you not just pry it out? The screws that are fixing the surround to the bumper are most likely behind the plate
By the looks of it the plate (complete with a black surround) is stuck to the bit you've circled.
Like the others have said just peel it off carefully leaving the bit you've circled still stuck to the car.
My front plate is attached to a surround (which only surrounds the top half of the plate, same as yours) and it lifts up to come off, give yours a try, my rear plate is stuck straught onto the boot without a surround, so I can't help you with that one
