Fog > Brake Modification
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
any one got a video of an is with this mod done i was thinking of it but i do like the look of the is with the nice 2 big lights lighting up
not sure what effect would be with 4 lights lighting up
would like 2 see tho
This one was taken to show the flashing brake lights, but the fogs also light up
  • 1 month later...
Is it the kit to have the rear fog's illuminate as a brake light in normal use but still enables it to light up as it should when its foggy? If so, do you know where i could get one from and the cost?
There are two ways of doing this mod
1/ Dual filament bulb holders giving separate filaments for each, AFAIK you need to do a small mod to the actual reflector to make it fit.
2/ Use a couple of diodes (69p each) to feed the fog bulbs from both the brakes and the fogs. This is the way that I did it.
MacRS200
do u know how to do the dual filament mod with the actual reflector? to make it fit?
Alan
In order to use the dual filament bulbs you need to get a dual filament bulb holder the same as the sidelight/brakelight one to fit into the fogs.
When I did it, in order to get it to fit the only alteration was the plastic tabs on the side that twist in needed a little trimming with a Stanley knife.
Hope this helps! :D
Hope this helps! :D
I did the diode version so the above sounds good to me :D
Hope this helps! :D
hi,
thanks :) i will give it a try tomorrow :)
Alan
ps i thought that the altezza got the right fog light units for the dual filament fitting? do u guys know where to get these parts from?
