Is200 Transmission Problems?
altezza69
Hi I have a is200 and I been having transmission problems. People advise me to check transmission fluid and color, I did check it and everything looks ok. A mecanic told me it could be electric problems, since the problems of the transmissions come and go. It has it good days where the car operates smoothly and perfectly. Then it has its bad days , where the transmission has a clunk in every gear, and a little bit heavy since it starts changing gear before time. What could it be???? I did disconnect the Battery to maybe reset the main computer but still!
  • 2 months later...
Hi I have a is200 and I been having transmission problems. People advise me to check transmission fluid and color, I did check it and everything looks ok. A mecanic told me it could be electric problems, since the problems of the transmissions come and go. It has it good days where the car operates smoothly and perfectly. Then it has its bad days , where the transmission has a clunk in every gear, and a little bit heavy since it starts changing gear before time. What could it be???? I did disconnect the battery to maybe reset the main computer but still!
hey there..did you manage to sort out yo transmision problems? if so I would appreciate to know how.. my Altezza As200 also ahs an on and off problem; Reverse sometimes does not engage, does nt happen everytime though.. have changed oil etc.
