Next Question
Sorry but my minds working overtime on things to do :whistling:
Next question
The sport rear spoiler shown below
would the bolt holes match thos of the accssory spoiler (below)
Next question
If its bolted on Chris, as you know i got my car new from lexus stockport, and the rear spoiler was just bonded on, with no holes at all :o
sorry chris i honestly couldnt tell you - it would be nice to assume they are but without measuring them who knows.......
oooohhh hold on doesnt the larger spoiler have 2 bolts on the ends instead of 1??
i seem to remember someone on here swapping the spoilers over and the holes were different or they didnt want to risk the chance of a respray so just swapped boot lids with another member.
the sport spoiler is bolted and bonded on
it will not come off without a lot of mess and a possible respray of the bootlid
it is also unlikely to come off in one piece !
been there tried it :whistling:
sport spoiler looks better in my opinion
in regards the holes, on the underside of the bootlid, there is only 3 points that you would be able to access the outer skin, or in this case a point at which you would be able to affix the spoiler, so, id assume that the spoiler both have the same fixing locations
Hey Chris,
I recall when I put my spoiler on, that I bolted them on in 3 places, plus 1 larger hole to run the wires for the LED.
So at a minimum, I'd guess the sport spoiler has 1 hole where the brakelight wires are being run from, even if the rest of it was bonded on without bolts.
If these coincide with the high level spoiler, you'll be fine :)
been to look at this one earlier and its another lemon, so back to the drawing board
You'll find one!! Stay on the hunt, there's still a few good examples of this car out there!
Flat spoiler has a load of screws holes ... think i drilled around 6 or more and has thin double sided tape as well...
Yup, I doublesided taped mine also and a bit of silicone sealent... (in addition to the bolts) mainly to protect it from water intrusion and rusting etc...
wants too much work
theres holes in the dash where a phone has been
it needs a rear bumper as someone has put horrid looking parking sensors on
both headlamps need changing as they are scratched
and every door moulding has damaged to them so they need replacing.
