Finally At Last.
Finally,
I've been trying to fit this for about two months but with the crap weather and a couple of wiring issues i've finally fitted this to my car by myself.
Took a few hours pouring over wiring diagrams and twisting myself into awkward positions to solder the ABS wires. But finally its done.
Fitted the adjuster in place of the ashtray as i don't need that so really looks the part.
Spent an hour or so setting it up today driving up and down with my laptop but it all seems ok now.
Haven't had the need to use it yet but apparently this is the nuts so lets hope its up to the job.
Heres a pic of the adjuster:
Also fitted today a push button start in place of the cigar lighter, it doesn't look stunning so i'm looking for a new button but it's all wired up at least:
Also currently the car is at the shop having the TRD rear lip fitted so when thats back in a couple of hours i'll post some pics of that up.
Thanks lads,
Just got back from bodyshop now, need to nip back tomorrow for a final polish but my rear TRD lip is on.
Here you go:
Just the side skirts and ARB's to go on then i'll have to stop modding for a while as i'm broke lol.
Looks good mate. The lip is definately better on a car than taking up space in my shed ;)
Is that the cheap start button from eBay? I have one of those at the moment and am in two minds about fitting it. This switch might match your blue LED dash better?
No eBay links seem to be working on here recently... don't know why!
If you want a proper good quality red button I think you will have to go for a Honda S2000 start button. I think Ellz has just fitted one recently and posted a pic of it.
Just out of interest which ignition wires does it connect to? Might try mine and see what it's like.
Yeah thats the one Jamie.
The sitch connects to a basic 1 coil and 1 NO switch relay.
Then the power comes from the cigar lighter plug, so it goes +12v, to relay coil, to button, to 0v.
Then the relay goes between a black wire with white stripe (starter) and a white wire with red stripe (battery) on the ignition barrel.
