Jbl Car Amplifier
redz_UK
JBL Power Series 300.4 600watt 4 Channel Amplifier
This can be used to run all four speakers or two speakers and a sub
This is from the POWER Series and has the same circuitry as the legendary JBL CROWN amplifiers. It really is one of the best in its range and not to be confused with the cheaper and inferior GTO range.
The tech specs are below but also comes with a benchmarked certfied power rating of 710w rms at 4 ohms
Power Output 125W x 4 into 4 ohms
169W x 4 into 2 ohms
358W x 2 into 4 ohms, bridged
Max Power 600W Peak x 2
Signal-to-Noise Ratio >95dB
Total Harmonic Distortion 0.04%
Frequency Response 10Hz - 45kHz ±1dB
Built-in variable electronic crossover with selectable slope
Dynamic Bass Optimization™ (DBO) circuit
Preamp outputs
Differential inputs
Internal-lighting-ready
Direct-Connect
Dimensions (H x W x D) 312mm x 432mm x 66mm
Slope-selectable variable electronic crossover
Direct-Connect
Full-range preamp outputs
This is mounted on a custom shelf/bracket especially for the lex that goes in the right rear of the boot. I will include this for anybody purchasing of here
This cost me £350 about 18 months ago, still retails at about £250 and is part pf the current JBL range.
JBL Website
Its fully boxed and has all the manuals and packaging. In Good condition, only slight marks to the rear of the plastic cover.
I have more detailed pics if wanted
PRICE: £120 +P&P or collect (fitting possible dependant on location)
also going on ebay tonight..
This topic is now closed to further replies.
