Is200 Sturtters And Now Engin Light Is On Help!
Motsey
  • 3 years later...
Hi, new to the forum, have just fitted new radiator, water pump and now need to fit coil pack to cylinder 1, is the installation as easy and unbolting and pushing new one into place?
Cheers
Hi Daryl welcome to the LOC,
I guess a one word answer sums it up although I would also check the plug on connector for damage, have a look down the plug recess for moisture and don't overtighten the securing screw as it may crack the case.
A gentle twist may be needed to assist removal but do not waggle the coil as you may break the plug insulation,pull straight up.
If you can get hold of some a smear of dielectric grease inside the plug tower will assist future removal.
