Amp Bypass Lead Help
Got you,
I though the IS200 stero was resonable ?
It is a very good unit, trouble is the ERR3 message is a major problem. It costs about £250+ to get repaired, so this is a cheaper method :)
EDIT: Stav beat me to it again, have to learn to type quicker :)
  • 2 years later...
not just a extension lead
dose it have fuses or anything in it? alos do all 4 your rear speakers work?
anyone tried to wire up an after market system onto the origional amp?
This is how I have wired in a head unit using the existing amp.
Head unit will need front and rear pre-outs though.
Not had any probs. yet and sounds good.
Hello , I own an is 200 and have taken off the original radio with one i have.
I have seen the picture and analyzed how i must connect the wire....but ouch, i did connect them but that crazy amplifiermakes a noise......like A COW.
even if i don't turn on the new radio.
And by the way, where can i find the negative wire for the nerw radio since i don't know where to look ?
any advice will be accepted thank you!
holy thread revival batman...... why dont some people just buy a bypass lead, it only cost £20, if people can afford to run a lexus then they can afford that.
the factory amp is not made to be used with aftermarket head units by the way.
I have made it work, but the sound is not as good as it was with the original radio, and plus i hea r a strange noise like if the stereo wasn't shielded...
Just 1 last question, the wires we have seen up there, do you know wich is for the front right channel speaker, front left, rear right and rear left? there are 4 colors white red blue and black, but my radio has only 2 rca outputs...how would you do? mix red and blue,white and black together?
LOL @ thread revival...does anyone know where i can get a lead for an Altezza, iv tried a lexus one that came with the dvd/cd player i bought but its diffrent, also bought an Autoleads Toyota one (i think the part num was pc2714 or something) ill check when i get home...but this doesnt work either :(
My Cd player is the one that has a minidisk player at the top, cd player at bottom and a tv/jap-nav....hopefully someone can help me.
  • 1 year later...
sorry lads im new to his hole lexus seen. i must say lovly car to drive but radio is a flipping nightmare the fella befor me ripped all the wires apart and i dont no where to start. i have a working radio and front speakers. what do i do abou getting back working. i have a full conection block that hasent been touched. with a very noticable orange wire running through it. the other has been cut off. any sojestions...............
  • 4 months later...
I found this schematic for a 18 pin match up with the MK2 20 pin connector
(only needed if you don't want to use an aftermarket system but have the old type connector and bought the top loader system)
PS go to a scrappy and cut the 20 pin connector + enough cable out ;) they will charge you about a fiver for it....
On the MK2 20 pin connector:
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Brown
Radio Ground Wire: Gray
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: White/Blue
Amplifier Output Wire Colors (at Amplifier):
Left Front Tweeter Wire (+): Pink
Left Front Tweeter Wire (-): Violet
Right Front Tweeter Wire (+): Light Green
Right Front Tweeter Wire (-): Blue
Left Rear Mid Speaker Wire (+): Black
Left Rear Mid Speaker Wire (-): White
Right Rear Mid Speaker Wire (+): Red
Right Rear Mid Speaker Wire (-): White
Left Rear Subwoofer Speaker Wire (+): Black/white
Left Rear Subwoofer Speaker Wire (-): Yellow/Red
Right Rear Subwoofer Speaker Wire (+): Red/White
Right Rear Subwoofer Speaker Wire (-): White/Blue
Wire Colors at Speakers:
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
the 2 missing wires on the 18 pin connector in the before mentioned wire codes are:
Green wire :for the Satnav (described as a BEEP)
Yellow wire : Mute (to be used for parrot or other sources)
