Superchargers And Foam Filters
Hi all, just a wee bit of info that may be of some use, was looking into superchargers and found out from a specialist that foam filters let in slightly larger particles that mix with oil from intake and can act like a grinding paste. It is possible that this can shorten life of supercharger.
Normal life is about 65,000 miles before a rebuild, this could be different due to the above and the way it is driven/its an add on mod.
By the way some of the engine bays are looking very sweet, may pop up and browse at JAE.
Regards
Tonio.
