Wiring Loom (stereo)
:question:
Recently removed the standard 6 disc changer stereo from my IS200 SE and found that unfortunately the previous owner had somewhat bodged the wiring behind the unit. Theres tape and exposed wire and all sorts, not to mention the non standard wiring that seems to be spliced in (badly).
F***ing Shambles!
Just wondering if anyone out there has photos of what it should look like or perhaps a Wiring Diagram so I can sort the whole mess out!
Thanx
AB
Why, what do you want to do?
If its fit an after market stereo then just tape the wires up and get a by pass lead from eBay that connects to the wires from the amp by the glove box and gives you an ISO connection for an aftermarket stereo.
Your wish is my command :)
From top to bottom:
2 x grey connectors are for A/C panel and clock etc. (not part of stereo)
Small white below and to right of them is for the aerial (i asumme its an active/amplified aerial)
to large white ones in middle are for the stereo
White, blue and black (hard to see but its on bottom right) are fore heated seats and Traction/Snow bottons.
and the small black at very bottom is the aerial lead
From top to bottom:
Cheers Mate, thats Useful.
I've now removed all the non-standard junk and its almost as good as new.
Thanxs again bud!
