Lexus Is200 Timing Belt Questions,pls Help
aragosta
Hi everyone,
I am going for my timing belt change very soon and hope that someone here can provide me with the Toyota part numbers for the items used. My mechanic says I need to get them myself from the shops.
IS200 2.0Auto (1G-FE)
TIMING BELT
TIMING BELT TENSIONER
TIMING BELT IDLER(Is this a bearing?)
WATER PUMP
What else can i change during this? PLs advice..thanks alot :blush:
hi.lexus do a kit which comes with all the pasts you need.the idler is a wheel with a bearring pressed into it.any good automotive supplier should be able to get a w pump for you or lexus.make sure you have all the parts before taking your car in as delays can be a pain.cheers
Thanks alot for the information bros... Over here, Lexus do not have a kit readily as they discourage doing the timing belt change eleswhere. I am actually gonna get it from a authorized toyota parts supplier and need the part numbers to make sure.
Anyone here thinks I should changed the engine mount/bushings? My car has travelled 120000KM!!
Thanks alot guys for the help. I've just managed to get all the parts needed and everythings done. In total i changed 7 items.
Timing Belt
Timing Tensioner
Timing Idler
V-belt Generator
Air-con Belt
P.steering Belt
Water Pump
And not forgetting the many litres of Toyota 'long life' coolant for a complete radiaor flush.Phew! This is one major service!! :whistling:
