Newbie
Lexus_lu
Thanks for the welcome!!
ill keep an eye out for you Ian M
Is there a club stand at Japshow this weekend?? i looked on the thread but didnt look like anything had been confirmed! If there is ill pop over and say hello!
Hiya Lucy, Welcome to the club :D Now dont forget to put some pic's of your lex on the site as we like pic's :D
http://www.lexusownersclub.co.uk/forum/ind...t=0#entry555548
Thank you for the warm welcome :D
Have just been reading about the dreaded error 3 on the cd player :crybaby: gutted i have that and thought it might be a quick fix :tsktsk:
Yeh its a common problem on the stereo most have swapped to an aftermarket head unit as there not cheap to replace :crybaby: Your not that far from me being in Derby so if you get stuck with anything give me a shout and i'll see if i can help with any problems you have? which shouldn't be much, if any as its a lexus :)
Thank you, ill bare that in mind!! Where do you take it to be looked after so to speak...do you know of any independent dealers/ specialist in the midlands area?
LOL yeh reading the posted about it, it seams like a common problem..oh well will just have to go shopping for an aftermarket one :D
I take mine to an independent garage that i've known for a few years but i know a few take theres to lexus Derby? There are some dealer reveiws on here somewhere to give you an idea where to take it?
If you do go for another headunit, you'll need a amp bypass cable and as you have the sat nav fitted like mine you'll also need a sat nav cable so the sat nav will still work when you swap your headunits over :whistling: but if you get stuck let us know and we'll help you get sorted :D
