Dash
there is a dial on the left hand side of the steering wheel with a pic of a light bulb,
now i am just guessing but i guess this is ment to make the speedo and other instruments brighter and duller?
is this the case as mine seems not to wrork if so is there an easy and simple reason
(such as a fuse somewhere)
thanks guys and girls for all help
:D
Yep, the dial brightens/dulls the speedo backlighting (also does the stereo as well).
Don't know how to fix a broken one though, sorry.
Mine works fine with & without LED`s in the dash :unsure:
Carnt u take it back 2 the place u got it :question: they seem like ok peeps when i went there is it still under warenty :question:
I have a GS300 MKII and the knob on mine doesn't do anything during the day, even if you turn the lights on manually.. but when it gets dark, the sensor on the dash allows the knob to control the dimmer..
No idea if this is same on the IS models..
Have you tried it at night, or just during the day.. (or covering the sensor if you have one)
John
