Eaton M62
Hi
Need some advice. I may be able to obtain the TTE supercharger kit will all the bits and pieces(, piping, cradle, airbox, pulley etc) everything except the compressor itself. I was told it's just an eaton m62 and locating a used one on eBay isn't too hard. That's true (i've found alot) but the snout assembly doesn't look anything like the TTE version (much longer) and the pulley size looks wrong too. So is it possible to change the snout and pulley on a used one so it matches the TTE spec? and does anybody know where to get the parts to do this?
Google isn't doing a very good job in assisting at the moment
Thanks for the help
very easy to do - remove the pulley and just unbolt the nose cone, then put the new one on. but far easier is to get a correct one in the first place, as the supercharger is from an early slk 200
Yes but the m62 from GM or Ford are more cheaper, 100 USD or less, and the size (diameter) of pulley from MB nor is the right one. If you choose the MB I think it's more reasonable and cheap change the pulley on water pump to preserve the ratio for boost.
Here there are snout for a M62 but is expensive and don't seems sufficiently short http://www.invasionautoproducts.com/superc...-m62snouts.html
dont know where u have your info from but it is incorrect. the MB supercharger does have the correct size pulley - i can only guess you are looking at the newer MB units which are fixed drive with a small pulley and not the older units that use a clutch and a larger pulley.
The older units are the correct versions to buy.
ok so you get a supercharger for a gm etc then have to spend x amount of money tryng to source a nose drive, and then send it over from the US (which will not be cheap)- it doesnt make sense. i would source a nose drive first or at least get a cost of the drive unit of the correct extension.
i have seen many superchargers of the correct type on eBay that were not too expensive - what prices have you seen?
i have seen many superchargers of the correct type on ebay that were not too expensive - what prices have you seen?
I think I'm not wrong, the oem MB Eaton M62 diameter pulley is 100 mm. and the TTE is 110 mm.
http://www.benzworld.org/forums/r170-slk-c...ulley-size.html
The year/model MB with M62:
Mercedes C Class C230 1994-1997 2.3L I-4 M45
Mercedes C Class C230 1998-2000 2.3L I-4 M62 3rd
Mercedes C Class C320 2001-2004 3.2L V6 M45
Mercedes SLK 230 Roadster 1998-2000 2.3L I-4 M62 3rd
Mercedes SLK 230 Roadster 2001-2004 2.3L I-4 M45
Mercedes SLK 32 AMG Roadster 2002-2004 3.2L V6 M62 3rd
and others cars
http://www.thehighspeedlab.com/Eaton_Price_List.html
and others cars
i would double check your information as i know the 110mm pulley on the supercharger is a standard item and is not replaced when the supercharger is used in the TTE/Bermani kit.
10 seconds on eBay produced this : 320313218684 its ended but is an example of what is available
and others cars
First sorry about my poor english and my ignorance about this issue, I hope you can understand me.
I think the TTE and MB Eaton M62 aren't the same pulley, one is direct and the other have a magnetic clutch, but if the difference of diameter is only 10% seems not problem (the valve or the bypass preserve the correct boost around 0.3 bar), and the clutch only work if it's plugged and receiving signal so no problem.
In eBay Europe there are few M62 and a lot of M45 and in eBay USA there are a lot of M62 but with large nose and there are more M90 still much more cheaper (100 USD or less).
As I don't have the bracket (in fact I don't have anything yet :yawn: ) to support the s/c I'm thinking to buy a M90 and build a bracket for it :duh:
I still thinking it's possible to build yourself a IS200 compressor kit with a very reasonable cost, I'll see ...
and others cars
Thanks Carles, this info is proving really helpful in my search. Sorry i didn't get back to you sooner. So far i've found a couple of chargers that look just like ours on eBay but they haven't specified if it's an m62 or m45. so i was wondering is there any danger in using an m45 rather than an m62 (boost/heat/bhp?)
http://cgi.ebay.com/ebaymotors/Mercedes-Su...sQ5fAccessories
Also they're insisting on a core return and i shouldn't bid unless i have a core :-(.
Another hiccup is the tte airbox. Can't seem to find a used one of those anywhere, but that wasn't a surprise, i don't expect people to be throwing that out with the garbage anyway.
I'll keep you guys informed.
There is a m90 for 50 USD in eBay (plus 100 USD for postage) I'm tempted but surely is better to wait a good price for a short nose m62 from Mercedes and avoid adaptation and boost pressure problems.
  • 4 weeks later...
Update.
So far things are progessing slowly but surely. I spoke with TTE and i've made my 1st shipment with the following
AM 27928 tube compressor to I /C
AM 27927 tube, I/C to inlet manifold
AM 27843 tube, bypass, 38mm
AM 27959 housing, compressor outlet
AM 27958 cable, compressor bypass spare
I know alot of the first order i probably could have made myself but i really like the TTE logo on the 38mm bypass piping :-)
In my next order i was thinking about getting the ecu extension, valve bypass assembly, cradle support for the compressor and AM 27930 housing, bypass to compressor
Anyways, I'd like to try to fab the compressor support cradle and the throttle body adaptor. I spoke with a local shop and they said it would go alot faster/smoother if i could get the mesurments rather than taking estimates and trial and error fitting on the engine and the supercharger hasn't shipped just yet (eBay usa off a slk230 with clutch) so i can't get it from there. Does anybody have/know the exact dimensions of those parts?
Also, the ecu extension thing, is there a good subsitute for it that isn't too complicated to install or should i just stick with the tte one?
Another thing is the pulley. I got an extra water pump pulley off an old 1G-FE and was hoping to use that. Is it the same size as the TTE pulley? I don't want to mess the size up and send a rod thru the side of the car...
all info/suggestions are welcomed. thanks
  • 4 years later...
was wundering if this is for real and if there is any summary to this.
If you mean a supercharged IS, then yes it's real and there are quite a few about. The full kit was available from tte some years ago.
Sorry, I know some people have used the merc, eaton supercharger as a replacement, or when assembling their own kit. The mounting cradle seems to be the most troublesome to source.
i think the cradle can me made uo from a any metal works place. aslong as it holds it and mounts to the engine i dont think it has to be exact same or?
i am looking at going down the eaton route is there anyone who has done this or knows any specialists thing that can assist in all the part etc if everything was in one place it would be easier than spending hours geting diffrent info for parts.
Sorry, i never did update this threat . I will answer any questions you have just post them up and i'll be sure to reply
About the Cradle, i wanted to do the custom fab at first but it was alot more complicated than i thought. I was never able to get detailed drawing and dimensions, so it would have been trail and error to get it done. eventually i just bought support cradle from TTE. It was worth it. You pay more for the R&D, but you get the peace of mind. In any case, after i got it, it was clear without those fab drawings i would have never been able to get it built correctly. There were support points on the engine block i would have never considered if i did it myself and the angles that were required. i probably would have ended up with lots of vibration cause i missed those little things
  • 1 month later...
Great thread for me, thanks!
My TTE Supercharger rattles a bit. Having had it taken apart and professionally cleaned inside and lubed, it's better, but the refurb showed some light scoring to the rotors and inside of casing. I'd like to replace the main S/C body.
(I stoopidly read google and bought a nose cone rebuild kit, to replace the coupler. Don't bother, there isn't one inside the unit - its direct drive, doh!)
Does anyone know for sure (100%), which is the correct replacement Eaton M62 Supercharger body pls?
Is it for sure the same body as a Merc 230SLK? Will it fit directly to the TTE nose cone, without modification? Will it deliver the same performance etc?
From the rebuild photos, there is a 'window' that allows inspection of the rotors from underneath. On E-bay, there seem to be several M62's, with square or triangle shaped 'windows'. Does this matter?
Cheers all and I would REALLY appreciate your help.
Flinty
http://www.ebay.com/itm/2000-Mercedes-Benz-C230-Supercharger-New-do-not-have-original-packaging-/331044662546?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d13ccad12&vxp=mtr
http://www.ebay.com/itm/98-99-00-01-02-MERCEDES-BENZ-C230-KOMPRESSOR-A1110900380-SUPERCHARGER-/281209762810?pt=Motors_Car_Truck_Parts_Accessories&hash=item41796873fa&vxp=mtr
Two links to the superchargers we need, one new, one used. When my charger needed a service, I bought a kit that covered the m62 with a snout, but i used only the parts that our chargers needed
I never paid any attention to the shape of the opening to be honest
Actually now that u mention it, i think i still have a spare kit somewhere.. i'll post pics of it when i find it
or you can buy this kit but you'll save more if you buy your parts separately
http://www.ebay.com/itm/MERCEDES-CLUTCHED-SUPERCHARGER-REFRESH-KIT-/370943878343?pt=Motors_Car_Truck_Parts_Accessories&hash=item565dfa64c7&vxp=mtr.
For anybody that comes to this tread long after these eBay links are dead, search eBay (eBay usa)for "mercedes supercharger" or "supercharger rebuild kit" and you should be able to get the stuff u need. "eaton m62" search will get you too many hits to other types that wont work.
