Front Lights
john_boy
apart from the headlight brackets, the headlight panel may be damaged as well as its only a thin frame of metal. If the panel is damaged then you dont need a full front panel only the section thats damaged as its available in bits as well. IIRC each headlight panel bit is about £30 from lexus bolton.
