Tte Rear Lip Fitment
Hando
On my last IS, my TTE rear lip was fitted with bolts + some form of adhesive all along.
On my current IS it appears the TTE lip was fitted with just bolts no adhesive - however after just over a year it's visibly coming away from the bumper and is no longer sitting flush.
For those who have the TTE rear: what is the fitting kit supplied? And what are the manufacturer's instructions?
Much appreciated.
Much appreciated.
On my 1st silver is200 (new) the lip did the same after 1yr, took it back under warranty, was ok then, but im sure thay used adhesive on it.
Do you mean it's dropped away from the bumper slightly (downwards)? Can you just push it back up?
Yeah exactly that - pushing it back up isn't helping though as there doesn't seem to be adhesive.
I think I'll take it back to Lex Guildford and get them to sort it out - they fitted it last year.
Just wanted to check if it's bonded or not - so thank you both for the info.
When I fitted mine with a friend I remember it was really a tight fit getting it on, I mean a real effort, two of us pushing and pulling like mad! Also yes there was a strip of adhesive running the whole length of the top of the skirt, the backing was red and had to be pulled off when the bumper was in place. As I remember it was split in the middle (the tape) so you pulled it off in each direction towards the sides.........where it was so tight I had to pry the bumper away to get the tape out.
Bolts hold it at the rear arches............fitted mine over 3 years ago, no probs so far, but it was a very tight fit.
Keith
Keith
Cheers Keith,
Sounds like they didn't bother with the tape which means they didn't fit it correctly. I'll sort it out with them.
