Hi Alan, try tightening/aligning the contacts to the tilt/telescopic control box
a grey plastic box in the footwell.
I recently had a fault fixed with my steering column tilt, it also cured the seat belt height control,which had not been working.
therefore ? this box also controls the memory seats and seat belt height?
worth a try, if you do this it can take a few hours to take effect, mine went intermitent for
a while, before working perfectly .... no idea why?
hope this helps
Rich.
Alan, there are about 20 pairs of contacts (little pins) in the tilt/telescopic control box.
each for a different function of tilt / telescopic / seat belt height / memory seats. If I am correct.
try adjusting them so they make a secure contact.
Or get your mechanic to do so.
It worked for me!
Rich.
  • 4 months later...
  • 7 months later...
hope this helps
Rich.
I have same problem bu cannot find the control box ?
willie
