The front w/s demist control is on, the heat is high, the fan is full and still the screen stays misty for around 5 mins while I have to drive like Quasimodo.
Why is the passenger side already clear? It was built as a RH drive car originally I guess.
Any ideas how to boost the performance in this dept?
Does anyone else expect better from the Lexus stable in this respect?
If the pollen filter is dirty it can take longer also make sure the inside of the screen is clean as greasy screen takes longer to demist, i'm not referring to finger marks but as the drivers side gets used the most its the side where there is the most build up.
As for settings, for quick demist press front windscreen button and make sure the A/C is on.
