Sc430
Rob's Lexx
Hi guys,
Couple of quick questions about the SC430:
are there many performance modifications available for it?
is it really bad on the petrol (i know its got a big engine, but seen combined figures of 24 mpg???)
Cheers
Rob
Lots of options TBH depends how much you want to spend / power your after.
Exhaust
Intake
LSD
3.76 gears
throttle controller
supercharger
cams & valves
headers
nitrous
Daizen sway bars
piggy back or ECU
short block, long block, head ported. opened up to 4.7, 5.0 or 5.2
custom twin turbo
If you going over 450 hp then you would want forged internals rods pistons and atleast a cooler on the transmission.
Without a doubt suspension needs to be sorted so coilovers and the best mod imo BBK being able to break late is awesome.
thanks matey, seen ur lex and its an absolute beauty. :) ;) B)
so they're about 280 bhp and 300 lb/ft of torque as standard off the 4.3 litre engine?? not that efficient on the power front when you think there's nearly a 4.5 litre lump under the hood..... :yawn:
what engine mods have you made matey and what sort of improvement have they made??
i wondered how they handled, u've kinda answered that one though, lol.
supercharger sounds nice - any plans for that urself fella?? what sort of bhp would that give assuming its a 'bolt-on' kit?
Only 280bhp from 4.3cc :o getting 344bhp from 4.2cc mine :whistling:
Guest inicol63
Rob if you want the SC430 then go for it as your lucky if you get 30 mpg out of the IS200 So your only be 6 mile per gallon worse off.
As you may know i have both cars and really don't mind getting 24 per gallon for the SC430 But i hate getting 28-30 out of a two litre car.
As Aquanuke says you can do what ever you want too these cars like super charger or whatever, but your going to need deep pockets.
I would change the wheels and coilovers as a starting point and then make up your mind from there.
So whats your plan for the next car?
Bolt on work pretty well on this car. Ive done..
S&S headers - expect around 22hp
Exhaust
Intake
Lextreme Torque Convertor - although the Dragon one will give you must better gains but kick in the CEL (check engine light)
Blitz throttle controller - which takes out the lag caused by the drive by wire system when you floor the car.
Daizen sway bars
Tein coilovers
And Rotora BBK
about 330 hp.
The supercharger options are very expensive and dont offer that much more
Blitz one is about 40hp, Toms one gives about 70hp both give over 400lb tq but cost £6,000 plus.
I plan to do a few more things in the spring/summer not decided yet but thinking about MVP camshafts and valves with a piggy back ecu (80-100hp) forged pistons and rods and 100 shot of NOS.
nice!!! sounds like a beast matey!!!
does the torque really make it pretty savage say when booting it from standing?? with that much torque it should be damn nippy...
i take it the mods for an SC430 are much more expensive than say for an IS - where availability and rareity is going to be an important factor??
Torque is king :)
TBH all the parts you will need to import from the states, shipping is a PITA as some items weight alot. But with the dollar so weak theres good bargains to be made on the exchange rate.
Torque is king :)
having to buy from the states isn't a problem
cheers for the info fellas, much appreciated
