Blower Fan Not Working
pmh118
hi i have a is200 se and my aircon pump belt snaped and broke the pump, i got a second hand pump seems to work fine,but the problem i am having is i have hot air coming to my vents and windscreen but only as a low blow pritty much none, the controls look fine i removed the airfilter behind the glovebox and the fan there dont spin i presume this is the reson i have no air blowing thru i havnt yet regased the aircon as i not so fussed about it i just would be happy to get some air blowing to as my screen fogs up so bad its dangerous
thank you in advance for any help and advise i get
i was trying to find the fuse/relay but not sure where to locate the right 1 i swopped a few fan relays around but im not sure where the fuse/relay is excatly is there a term for it as in my fuses i have fan 1 fan 2 fan 3 and then 2 other fans but they are relay switchs
