Help Please
antran
Hi everyone, I bought my altezza few weeks ago. The car itself need a bit of work but nothing major.
I tried changing one of the belt(4pk780) over the weekend, but I run into a bit of problem.
I think I my have broke the bolt that you use to loosen/tighten the tensioner bearing. Well, the bolt shifted to a 45* angle = (
the tensioner bearing is still very tight, is not moving at all. can it be fix or need to be replace? thank you
I will upload few pics later on, just that my mobile is out of Battery. The pictures will explain a lot better the I do.
Andy
