Decat Pipes
Hostile Smoker
  • 1 month later...
Its different on the 300 mate,
on the 200 theres three sensors. the two in the manifold control timing etc, and the last one is just checking the cats working. i replaced it with an o2 simulator
Thank you for that! There seem to be 4 sensors on the manifold, 2 either side of the pre-cats and before the main cat. Where can I get an O2 simulator and where do I put it? ( no silly answers please !!! ) :)
an o2 simulator replicates the signal the sensor sends but thier pretty simple design and wont adjust as the engines running so you may need quite an advanced one.
But you wire them where ever you can fit them. I've wired mine to the wires right back in the ECU.
